ok so sound still there, like a faint rattling (faint as in i cant hear it unless i put my head under the desk or next to the case.
Anyways machine been running for a few hours now doing various updates and installs, browsing etc.
CPU temps are staying anywhere from 20 to 25 ish
Mobo temps are anywhere from 18 to 25 ish
I have the corsair pump plugged into the molex and the 3 pin (one wire) from the pump connector in my CPU fan header.
I have the pump set to lowest profile (quiet), but my fan speeds for that header say 2100-2200 RPM constant though not paticularly noisy.
is this an aggregate of the 2 fans attached to the radiator ?
as in the profile mentioned here
http://www.corsair.com/blog/underst...es-h80-and-h100-cooling-performance-profiles/
says the quiet profile is RPM of 900 to 1300, my fan speed being 2000+ is in the performance profile measurement.
My side fan is plugged direct into PSU as cant reach the header on board.
My top exhaust fan is connected to CPU opt header and RPM at 1100 give or take
My front intake fan is connected to PWR fan 1 header and at about 100 give or take
is this all sound normal ?
The main question is the speed report of the CPU fan as it seems to exceed profile, even though they get louder when i turn the profile up
