Tamzzy's back to air-cooling ITX build
Man of Honour
26 May 2012
@Plec @orbitalwalsh @Journey @an0nym0us @robfosters
IT'S HAPPENING!
Ryzen 3700x £300
Aorus X570I PRO WIFI £227
2x 16gb Crucial Ballistix LT e-die £146
2x Corsair MP510 960GB £190 total
EVGA 1080ti SC black edition £570 (reused)
Silverstone RVZ03 £80
Seasonic Focus+ Gold 650w £60 (reused)
Cryorig C1 (with Gentle Typhoon fan) £53 (+ £10 for fan reused)
Total damage build cost: £1636
Pics all seen before...
Beefy wifi antenna lol
I'm hoping that is all goes nice and smoothly for you. I spend half my days (or it feels like it) designing and testing 1U systems so small cases are something I am very familiar with.
Sigh. Coming from a fractal design case, Silverstone build quality and QC is cack...
The plastic bits feel very cheap... especially the adapter that holds the GPU...
Have you rage quit yet, @tamzzy? :D
*Will you be admitting that you activating the RGB on the case?
EDIT: Missed this:
Although, once grafted together, the build should be considerably sturdy (thinking of internal assembly/design). And, once it's built/working and the 'RGB is cycling through its repertoire of preeedy colours' - you'll forget about the adaptors/quality on the inside.
