Technical Problem
24 May 2009
North East
Feel free to move this if it is in the wrong section just not sure where to post.
I just bought a hard drive cradle so I can get access to my old HD from an old rig. I want to get some pictures off there but it wont let me saying I need administrator permission (I was the admin on my old HD)
How can I give myself access to these files? :confused:
im guessing that there was a password when you ran this disk yeah? have you tried doing a "runas" and under username putting "<computername>\<user name>" and then the old password?
havnt tried this myself but would be the first thing i tried
ok I cannot see a quick way of doing this from win7 so:
Start, Run, enter CMD. on command line type
runas /user:<computername>\<username> <drive mapping>
You will then be asked for the password
Drive mapping = C: or what ever your machine has given the drive, probably E: or F:
You could take over permissions on the current system
properties > security > advanced > owner ......
If you could do that wouldnt it defeat the point of having a password protected system?
You would have thought so but that actually worked, pretty pointless getting a password on your computer then really as if someone wants in just take the HD and change the permissions :rolleyes:
But it worked for me so happy days, thanks for the advice chaps
Not really - standard Windows file permissions are only designed to provide a basic level of security and they work well for their intended purpose. It would be a bit awkward, especially in a corporate setting, if they weren't ultimately subject to the authority of an administrator account, which is one reason why such accounts should be used with care.
If you really want to protect data from anyone who might gain physical access to the hard drive, you need to use encryption, but you have to be careful about managing and backing up your keys or it will end in tears - eg in your situation, you *wouldn't* have got your data back, ever... :)
