Is teeth whitening permanent if done at a dentist ?
arnt crest stripes a thing you would use as a measure to ensure your teeth stay white once youve had them whitened?
true
actually a good thing about using domestos is that you can start off by just dabbing a diluted amount onto your teeth then build up the concentration until you have the level of whiteness you want.
The chemical that whitens teeth is limited in toothpastes. It's not enough to actually do anything.
No whitening toothpaste, most of them are extra abrasive to make your Enamel thinner and look whiter.
im not gay!just come out of a long term relationship and thought id treat myself. if its anything under £250 ill maybe do it as long as it lasts at least a year
