Hi,
ATM Setup is as follows:
Small white box with white wire to motorola cable modem, usb from this cable modem to pc, rj45 cable from this cable modem to the pc....
Now I want to include a DSL router to the setup as (ADSL router will not work apparently as its a cable line) so....
I will take the rj45 cable and the usb cable from the modem and plug them into my dsl router....What do I do with the white cable which goes from the small white box to the current cable modem?
I am very confused because there is no normal grey or white wire that plugs into the phone socket....
Can someone pls clarify???
Thanks in advance
Thanks in advance
		 (i'm using the GS for my NTL cable).
