That was interesting. I limited myself to using only notepad, to see if I could do it with just logic. I suspect there is a more elegant solution than the one I came up with.
I've worked out plenty of substitutions for all the equations, but as of the last few minutes haven't actually managed to set one up to solve for one particular variable. Clearly my brain is getting soft!
I think I have the obvious 10th equation that you speak of, but I don't see how you get nine equations from the table. Four rows and four columns make eight, but one of the rows is the same as one of the columns, so you're left with just seven.
I didn't even use/look at the grid. I just wrote the equations out and crossed out the duplicate. 1st column, 1st row and 3rd column gave me three letters right off. After that it was easy.
Ah sorry my mistake. 7 equations from the grid plus another obvious one made up from the fact that each letter is an unique number from 1 to 9.
I solved it by logic anyway but from 3 equations its easy to work out what 3 numbers are so that would then leave you 7 equations and 6 variables so you could then solve the rest by simultaneous equations.
Pretty clever puzzle. Had to assume to values of two symbols at one stage, but that assumption proved to be correct as all other numbers then fell perfectly into place.
Yeah I got to the same bit and I thought it could be one of three numbers but saw that in fact it couldn't if you thought about it and could only be one.
Would have been quicker to try all 3 than work it out.
