I've been chatting to Raijintek about running a competition for you guys, it is a forum competition only (Woohoo!) and we will be giving away some of their award winning cases!
It is simple to enter, just tell us which case you would like to review and why, and then if you win the prize, you review it on the forum and on the Overclockers UK website. Simples!
We have 3 cases that we will be giving away, giving you a greater chance of winning!
The first case up for grabs is the Paean, it is an incredible case that can be used for not only testing hardware, you can also build a stunning showcase PC!
https://www.overclockers.co.uk/raij...atx-bench-table-showcase-black-ca-039-rt.html
The second case is the Metis Plus, it comes from the original Metis with some extra features, it is a small footprint powerhouse, allowing you to either fit a nice living room PC inside, or even a gaming PC!
https://www.overclockers.co.uk/raij...um-mini-itx-case-silver-window-ca-03f-rt.html
The third option is the Asterion, it is a high class midi tower case with a nice window allowing you to build a full ATX PC in style!
https://www.overclockers.co.uk/raij...m-midi-tower-case-black-window-ca-037-rt.html
The competition ends on the 17th of April, so make sure you let us know which case you would like to review, and that will enter you into the draw! Good luck!
If you use social media, follow Raijintek on Facebook and Twitter using the links below:
https://www.facebook.com/raijintek/
https://twitter.com/RaijintekCoLtd
