Hey guys!
I think I'd go for Asterion Plus.
Why? Well, design wise it sort of resembles my own Aerocool 800. The difference is this one has very nice and neat rubber seals on holes where cables goes through. This allows a very neat cable management. You can see here my own built workhorse. Aerocool case is amazing to fit radiator at the top of the case. and my Radeon Fury X radiator at the back. The front facing fans now upgraded to very silent 140mm fans by Nanoxia. All of those component would sit nicer in this case and I finally would see point of buying custom cables for MOBO, GPU and ATX power just so everything would look nice. Building this PC I had very limited budget so went for cheap yet reliable case with good airflow. If I have had extra £90 I would have gone for Asterion.
Anyway I'm quite good at IT builds (built over 200PC's) but most of my builds were on tight budget. Asterion case would finally make my computer more premium and my great hardware would finally take a "throne" to sit in, instead of this "cheap gaming chair".
Thanks And I hope I'll get that one for review!
It would be available as two videos. First - overview of the case, second - full migration of components from AeroCool 800 to Raijintek Asterion
