- 22 Apr 2006
- Arms reach from mouse
Firstly there is a reason i have not put this in Monitors section, all the threads there are specific and i'm just after some general info on TFT's
Looking to buy a cheapish 19" tft and was wondering about the Hanns-G widescreen on special this week.
1. When i have seen widescreen tft's in store i have thought they look small, what do you guys think? Is a 4:3 aspect better or the widescreen.
2. Will i have to have games that support widescreen format or will XP sort them all out to fit the screen perfectly?
3. Is this spec any good?
Product Description Videoseven V7 L19WA - flat panel display - TFT - 19"
Device Type Flat panel display / TFT active matrix
Colour Black, silver
Dimensions (WxDxH) 46.9 cm x 19 cm x 36.9 cm
Diagonal Size 19" - widescreen
Dot Pitch / Pixel Pitch 0.285 mm
Max Resolution 1440 x 900 / 60 Hz
Colour support Up to 16.2 million colors
Response Time 8 ms
Image Brightness 300 cd/m2
Image Contrast Ratio 500:1
Audio Output Speaker(s) - stereo - integrated
Interface VGA (HD-15)
Power Consumption Operational 43 Watt
That is the alternative widescreen.
4. What should i be looking for i.e brightness, viewing angle, image quality? All the important factors when buying a TFT basically.
Thanks to anyone who can help,
Foehammer
Response Time 8 ms
Foehammer
