thanks amd for disabling down sampling.
Caporegime
22 Nov 2005
Thank you amd you are so kind for making sure all the programs that can force down-sampling no longer work with your precious drivers after 13.1X something you have done in the past before long ago :rolleyes:
this is the last ****** straw for me your AA modes are already crap compared to the ones Nvidia can force with Nvidia inspector! and down-sampling was the only way to get crystal clear graphics with 0 flickering in some games.
off to the dark side I go once again.
and yes I'm aware there is a workaround by unstinting 13.1x+ , installing an older driver version , uninstalling all of it's driver files apart from the registry data and catalyst config , installing the new drivers but keeping the old driver settings intact.
which frankly I find a ridiculous workaround to something there is no reason for amd to get out of their way and get rid off....
Thanks for the public rant, I'm sure everyone appreciates it.
Couldn't you just use CRU to set up a custom resolution? I'm forcing 80 Hz on my 2560x1440 monitor using this method.
http://forums.guru3d.com/showpost.php?p=4512526&postcount=167
some people said it hard locked there comp when they enabled the resolution so I'm not even going to bother trying it
and I'm sure anyone else wondering why the downsampling tools no longer work do appreciate it rather than faffing on with oem monitor drivers wondering why it no longer works
sounds like CRU actually overirdes your monitor and forces it to display that res anyway where as the old "amd downsampling tool gui" the res already got scaled down before the monitor got any signal.
so even if you were running 2560x1440 or whatever it would still be displayed as 1920x1080 on your monitor but with all the extra clarity
Have you reported this to AMD? They have been fairly rapid at fixing user reported issues lately....
I don't see why amd care about third party tools and it's likely a driver decision.
I'd guess probably less than 10% of people even know what down sampling is and use it.
amd likely don't care about losing another 10% or so of their userbase to nvidia where its so much easier to force AA levels with nvidia inspector than it ever was faffing around to get good IQ on amd.
Turn on system restore>create a restore point, try it.
If it doesn't work, Safe mode>restore computer.
Simples, though I understand your frustration, they both disable things when they feel like it.
No small print on my 9800gt box about disabling PhysX when an Amd gpu is present.
You care enough to rant [which took more effort than filling in the form] but its not important enough to fill in the AMD report form, i guess its not important.
well I'm sure amd people still roam around the types of forums such information gets posted on and they are likely already aware.
although no one from AMD appears to have made any comments
The amount of tech forums on the web and you're expecting AMD to read all of them regularly...?
I'm so glad this wasnt something nvidia did, we'd be up to about 3 billion pages by now slating the crap out of them.
to the OP, maybe best sending a quick email off to AMD ?
Why not wind your neck in a bit and think of the era not so long ago when you had to wait for magazines to ship with floppy's for fixes and drivers...
If you cba to inform them, then how can they have a chance to fix it?
If your not going to tell them about it then how can you expect them to sort it?
Just going on a rant over them not fixing it while never actually complained to them is a bit silly.
no but I know for a fact some of the forums I post on have amd driver guys posting on them.
and none of them have ventured into the downsampling threads , one was asked a direct question in another thread but never answered.
anyway it's not a new issue its been going on since 13.1 and we are in 13.6 beta already and 13.4 whql.
people have reported it even if I have not.
BTW
CRU definitely overides your monitor and forces it to run out of spec and can kill your monitor so for anyone looking for an alternative to "amd downsampling gui tool" which is a third party tool and not supported by amd then look elsewhere or to the green side and nvidia inspector.
BTW
AMD have been very good at fix issues reported to them, posting in some random forum is no guarantee AMD's engineers will ever get to see it.
If this really is something you wanted fixed, and are not just using it as an advert for Nvidia you really should report it through the channels AMD have provided for exactly that purpose. here... http://www.amdsurveys.com/se.ashx?s=5A1E27D20B2F3EBB
BTW
They as BEEN ZERO reports of CRU damaging displays. So dont spread junk here.
If you would report the issue and anyone else who have this issue to amd report page it might have been fixed by now.
So its your own fault for not reporting it.
I don't know what it is and I'm curious. Anyone care to explain?
And you really should report it arknor. Even if amd people visit threads, they may not be engineers, and even if they were, the company may have a policy of only acting on things they have a bug report about. It would be daft to devote engineer resources to every wild claim made on the internet.
basicly you set your games resolution to something higher than your monitor resolution can higher.
I used to run 2560x1440 and downsample it to 1920x1080 (with amd downsampling gui a program not made by amd) your monitor would receive the signal at 1920x1080 but with the clarity of 2560x1440
like when you take a screenshot of a game
and then you half it and it looks so much more crisp and sharp and it's like AA but on steroids because it does not miss a single pixel of the screen.
heres an example.
pcars rendered at 2560x1440 > to 1920x1080 with 4xAA
look at the lines of the car the body panel edges etc and how smooth and awesome they look like it's not even a screenshot of a game...
with just 4x AA
whilst the second image has few jaggies all the lines etc look wierd and fuzzy the clarity is utter crap in comparison
You're telling me overriding your monitors EDID and running it out of spec is perfectly safe with no risks at all?
Notes:
This program adds monitor resolutions, not scaled resolutions. Lower resolutions will be scaled up if GPU scaling is enabled, but higher resolutions won't be scaled down by the GPU. Higher resolutions will only work if the monitor can handle them.
where as with amd downsampling_gui the actual scaling was down before the signal reached the monitor so the monitor for all it was concerned was running in spec
anyone who thinks overriding your monitors EDID and running it out of spec must be on crack if they think there are no risks no matter how small they may be.
I'm not willing to risk running my monitor out of spec no matter how small the risks might be so my only option if I want the clarity I had grown used to would be to switch to nvidia and force super sparse grid sampling with nvidia inspector.
I know your supposed to be able to force high levels of AA with radeon pro or whatever it's called but I could never get it to work in everygame like you can with nvidia inspector
