Thanks and first build problem
6 Sep 2007
Hi
Ive just bought an evga nforce 650i, an e2180 some Geil RAM, an OCUK 1950pro and hard drives and dvd-ws and stuff.
Would just like to say thanks to everybody who's helped me design a new system.
First problem Have processor in with cut away bit in the right place. But the lever wont go down. Having to exert a lot of pressure?
thanks
Masten
Put the pushpins so that the rear of the arrow / back of the lever is facing into the heatsink, push them down in a diagonal order (like top left, then bottom right, cos if you do one side then the other it makes it more difficult).
ok, thanks - got the proceesor in. Thought the lever would snap in but no just needed to put pressure until it went in.
Heatsink and fan next. Is that row of 3 grey stripes the thermal paste?
Then for the headers. How do I konw what all the wires do
- two thickish grey ones
- one blue and white coiled
- two mulitcoloued with 4 or 5 different pins on the end??
And where to put them on the motherbaord. The evga instructions are horrendous. Would it have been that hard to put a proper instruction manual in
thanks
MAsten
yep it spreads itself out on it's own when u attatch it.
the 3 stripes is thermal paste yes
do you mean the ones for the on off switch ect?
if u do thent he colourd side is usualy the + one
ones for
- on off switch
- reset
- front usb ports
- front audio ports
- hard drive activity,
- on light
- speaker
That's all I can think of. So why so many wires all coming from the behind a panel in the bottom front of the case?
Putting heatsink on. Got one corner snapped in but on the other corner the black bit has snapped in but its not in the hole and wont go in cos its too bg and i cant get the black bit out!
Im sure I didnt do that
How do you remove a refernce intel heatsink?
erm... i can't remember i think you have to turn the black plastic things around to release it... hold on ... i'll have a look at mine...
hi
it's ok thanks, I got it off with a lot of faffing and swearing. I have 3 pins all in now but one is only 3 quarters in. Its secure and solid but wont snap in. I cant press any harder without breaking the motherboard. Will it do.?
Got to say it. What a crap design!
hi
well you do have to push really hard, i thought i was gonna break my board when i did it for the 1st time, depends how much the board is bending, if you support the back of the board properly you SHOULD be fine.
Ok. Ill leave it as it is. Seems secure
Next thing. Got blanking plate in case but what are those bits sticking out of it for. I cant get the motherboard in because of them?
could you be more specific?
and about you're cpu cooler, i'd check you're cpu temps in the bios when you get it running, to check it's making a good contact.
Hi
I dont know how else to put it - the blanking plate for this motherboard (evga nforce ultta 650i) has got bits that stick out into the case behind some of the holes for the ports.
Hi
oh right, well does it still line up with the back of the motherboard? if so then it doesn't really matter, as far as I'm aware.
well I bent them all back thinking it was some way of securing the motherboard a bit more which seems to work. Dropped motherboard in and has gome down on the pins but now its too low and ports dont line up
