Thanks and first build problem
yes, hard to explain isn't it. HAve found some red washers that came with the case. I think I have to put these on to raise it a bit.
Many thanks for your help. Much appreciated
the things that the motherboard sits on are little plastic things the motherboard snaps on to. I guess the red things are spacers yeah, cept I only got 3 with the case which doesnt make it high enough. Guess I have to go and get some from somewhere?
spacers are usually metal, so im still not sure wht ** on about lol
Everything that came with this case is plastic - the risers were too. Anyway I got it on in the end. The problem was I didnt have enough risers on the back end of the motherboard so it was sinking down. Fixed that now. Motherboard is in
Many thanks for the support and advice
Masten
Masten
np, you're risers were plastic? that's odd. what case is it?
