Couple of problems with this. Compressing air is very inefficient, lots of the energy goes into heating the air rather than increasing pressure (typically a multi stage compressor might reach 60%, a typical single stage compressor *much* lower than this). Couple this with the likely poor efficiency of the two stage engine used in this car and the overall energy efficiency is not looking good. The fact that fossil fuelled pre-heaters are needed for longer ranges are a double whamy in the energy consumption stakes.
Secondly, there is always a problem with how to provide heaters for the cabin when not using a combustion type engine (and if the pre-heater isn't used). An expansion engine such as this will actually get cold during use rather than hot, due to the expanding air. Cabin heaters in IC engined car normally have an output far higher than practical for electric heating.
