Interesting price point, wonder what the UK price will be?
It's already appeared on a UK store for £650 a week or so ago. Be interesting to see if it gets the u.s. price that's meant to be 549 shortly.
It would need to be priced at £550 for it to make sense.Interesting price point, wonder what the UK price will be?
4070S is gonna clean up if they try to sell them at that pricing, just not cheap enough for the strong hold Nvidia have got (plus the vastly better upscale/RT ofc).
The 7900 GRE is 5% faster than the 7800 XT, if that, because the board power is exactly the same, 260 watts vs 263 watts, there is no place for it to slot in to, AMD idiotic new naming Scheme is in this case not the problem, they are essentially slotting in a 16GB card where one of their own already exists and trying to charge $50 more for it, the same performance.
Clock it up a bit, give it a 280 watt board power and 19.5 Gb/s memory IC's to put it between the 7800 XT and 7900XT, charge $550 for it and bring the 7900 XT down to $650.
There is no point in dropping the 7900 GRE as is, no one is going to pay $50 more for something with the same 16GB and +3% performance over the 7800 XT.
Edit: and call it the RX 7900 or RX 7800 XTX, drop the GRE thing....
If they hadn't hobbled the OC potential it could've been worth paying attention to, as it stands i can't help but wonder why they even bothered due to it being so close to the 7800 XT.
I’d love for someone at AMD to explain what they were thinking seeing as they already had the performance data 6 months ago. I cannot remember another GPU launch as odd as this in quite a while.
They should have just called this the 7800 with the 7900XT being the 7800XT like they did last gen with the 3 cards using the top chip.They should re-market it for the western market. 7800 XT Superishor anything, 7900 GRE just sounds horrible.
A new replacement card should have more CUs not the same, the same for CUDA cores, if a new tier of gpu only has the same then it’s essentially a downgraded tier like the 4070 for example which is clearly a 4060 type card.Meh. People get to caught up too much on naming schemes /branding.
The RX 7800 XT is essentially a successor to the RX 6800 because both have 60 Compute units.
The RX 7900 GRE is sort of a successor to the RX 6900 XT (both 80 CUs), but a flawed one unfortunately. The spec needs beefing up, but I imagine AMD is worried about it performing too much like the RX 7900 XT if it had the same GPU and memory clocks.
It looks like boost clocks of 2400 MHz should be possible (with higher memory clock speeds as well), which makes me wonder why an upgraded version hasn't been revealed yet, and priced at ~£600. Maybe AMD never produced enough Navi31 dies in general.
After watch HUB video I'm left feeling the the GRE is a missed opportunity, crippled it with 18 Gbps VRAM and then locked down memory overclocking in the BIOS is a boneheaded move. It's like both AMD and Nvidia go out of there way to make sure there no obvious 'must buy' product in their lineups.
It depends on the architecture entirely, and how much of an improvement there is.A new replacement card should have more CUs not the same, the same for CUDA cores, if a new tier of gpu only has the same then it’s essentially a downgraded tier like the 4070 for example which is clearly a 4060 type card.
Agree entirely. I'm just about still running a Vega and desperate to upgrade to something that can run 1440 for the foreseeable. But AMD are as much of a turn off as Nvidia currently.This, its stupid, come on AMD, put some more effort in to this, you make good products but damn it your marketing or product relations teams or what ever entity it is making these daft decisions are low effort and incompetent, do better.
Even if this is stock you need to get rid of you could be more inventive than this to do that.... This is not a good look.
