Beats the majority of cards at a better price pointPointless card.
I think the issue is that the spec isn't quite good enough, with some parts actually worse than the RX 7800 XT.If they rebranded GRE to RX 7900 or RX 7900 LE with SKU's between £580 to £620 would work. Still to much money but so is the whole GPU market.
ThisClock it up a bit, give it a 280 watt board power and 19.5 Gb/s memory IC
Edit: and call it the RX 7900
But but but it’s for the ladies.The 7900 GRE is 5% faster than the 7800 XT, if that, because the board power is exactly the same, 260 watts vs 263 watts, there is no place for it to slot in to, AMD idiotic new naming Scheme is in this case not the problem, they are essentially slotting in a 16GB card where one of their own already exists and trying to charge $50 more for it, the same performance.
Clock it up a bit, give it a 280 watt board power and 19.5 Gb/s memory IC's to put it between the 7800 XT and 7900XT, charge $550 for it and bring the 7900 XT down to $650.
There is no point in dropping the 7900 GRE as is, no one is going to pay $50 more for something with the same 16GB and +3% performance over the 7800 XT.
Edit: and call it the RX 7900 or RX 7800 XTX, drop the GRE thing....
An overclocked 7800xt gains around 12% over stock and match’s the 7900 GRE at stock. Rather pay less and overclock tbh.The RX 7900 GRE is getting a global release on 27th Feb 2024:
Link:
https://videocardz.com/newz/amd-radeon-rx-7900-gre-to-launch-globally-on-february-27th-at-549
It's targeted at the RTX 4070, at the same price, and is unsurprisingly faster in just about every game, according to AMD.
Still, it seems like a missed opportunity, there's basically nothing competing with the RTX 4070 Super, which was previously priced at £540 (but is costs a bit more currently for the cheapest Zotac model).
Presumably, the specs are set in stone now, as they have been listed here since the initial limited launch in July 2023:
https://www.amd.com/en/products/graphics/amd-radeon-rx-7900-gre
So, that limits it to:
- 'Up to 2245 MHz' for the GPU Boost clock speed
- 'Up to 18 Gbps' for the memory speed
Gains around 5% I believe once overclocked and the limiting factor is the power limit. Vram speeds are gimped vs 7900xt’s bandwidth.Maybe it will sell better in the US market?
Stick a chonky cooler on these, and maybe they will overclock a bit further?
They might refresh the 7800xt and release a 7850XT which would be reflecting a “7900” slotting in and replacing the GRE.I guess they might still do a proper 'RX 7900' release, but it would be weird to have both in the lineup.
