The Sound BlasterX AE-5 Owners' Club
Thinking of retiring mine. Just got an aorus x570 master. Sound ain't bad at all.
Annoyingly it doesn't have headphone jacks at the rear.
Anybody having issues with the center/sub flipping randomly if you have windows set to 5.1 while using the AE-5? If I set it to stereo in windows it's fine and I can get surround via the acoustic engine but I would like pure sound while gaming not post-processed....
This is on a 3900X with an X570 Aorus Xtreme.
I'm staying. Plus this is the longest thread I've ever created. Lol.
X570 master is very good. But just listening to some hi def on YouTube and you can tell the difference.
Plus positional audio in games is better.
Onboard sound is better than it has ever been, but I don't think any are superior to the newer SB products, like the AE-5.
Problem I find is that in most cases onboard audio is the last thing they think about so even when a good sound processor is used you often find that somewhere in the circuit for the sound side there are traces that are less than ideally positioned relative to sources of switching noise or other interference, etc. and/or some cheapest possible general purpose electronic parts used in or close to the signal path, even when most of the implementation uses decent parts, which do result in an impact on the sound however subjective it might or might not be (though no guarantee a soundcard is free of that).
hello
i have this amazing card for more than year and a half now and it is been really good
i bought dt 1990 pro couple of days ago and have been running it through the headset input and direct mode which would basically turn off all filters and pretty much make the sound card work as a DAC AFAIK
is this the best or i would need to by a DAC or something like that
hello
You would have to buy a very expensive DAC to do better than the AE-5 in direct mode (subjective taste in audio aside). The only thing is in direct mode it does limit how many applications, etc. can access the hardware so if you are using multiple sources of audio you might find some aren't audible in the headphones in direct mode.
Just got the ae5 plus can confirm it's fantastic only thing im missing is volume pot on my schiit magni
have to adjust sound in games now if its too low or loud, no biggy though as i'll swap to a keyboard with volume control buttons
directional audio is much better than dolby headphone on my dx, it's actually crazy how good the directional audio is on these
No idea what dts and dolby ecodings for though presuming just for when you connect something dts ?
There s a cold boot issue on these latest drivers, sometimes when i boot up it's like the soundcards not plugged in the only thing that solves it is reseating the card in the slot
I know its the driver because its only happened on these newish updated firmware and drivers, doesn't happen all the time
Hmm, there is a firmware update for this card?
Is there an actual discernable difference between onboard audio and a dedicated sound card, particularly if you use wireless headphones?
I thought that. I was confused at first because I was never aware any sound card ever received firmware updates.
cant answer the wireless headset bit but I have used onboard audio since 1996 when they introduced the ATX format as it was convenient. I was tempted for ages to upgrade as I always had SB16, AWE32, AWE64 etc but only upgraded this year to the AE-5 plus and WOW WTF was I thinking all these years. Chalk and cheese is a ruddy understatement.
I suppose if you are using an expensive wireless set then it will be pointless but I use my Sennheiser's on the cable now so I can better shape the sound and also with 5.1 encoding the audio quality for video and audio is just soooo much better than with onboard. Kinda makes you wonder why one of the OEM's like ASUS or MSI dont add the Creative chip on to the board especially on there Uber priced boards, it would be a killer feature.
Depends how the wireless works.
The AE-5 in direct mode has a punch and quality I've not heard from any onboard solution yet - it is even noticeably better than the AE-5 in normal modes (in direct mode only 1 or a limited number of applications can access the audio device so it isn't great for 24x7 use - but great for music use on its own).
I have the Logitech Pro X Wireless. Uses Lightspeed USB. No idea how it works though.
