Newest drivers are up now if anyone's interested.
Seems to be missing a lot of options from the Connect version some they will add in a patch like RGB Lighting. My Soundbar is redundant now because the Stereo Upmix option is gone and setting your headphone impedance is not there seems to be a watered down version of the AE 7/9 one i think at the moment. I like the interface though that's just me.
Thanks I've seen the impedance option missed that i use Direct Mode as well I've noticed you can't use any of SBX profiles now in that mode there locked off which is probably correct for pure unfiltered sound it was available in Connect. Slow Roll Off seems to be the best i read not sure.Did you check playback section, select headphones and then the grey control icon the impedance option is in there. Not sure about stereo upmix probably somewhere hidden in those settings. I also like the Direct mode, creative say this is the purest stereo mode imo its the best for everything music and film wise ( I don't game)
Nice creative did an update since it felt like they gave up almost, now all they need to do is ramp up Creative AE-9 to retailers properly oh and drop it by £100.
New drivers are not really worth installing why did they even bother![]()
Have you checked DPC latency?
Also make sure Windows isn't doing updates stuff in the background or the anti-malware service - I find Windows 10 poor for things getting busy in the background.
Would a failing PSU or other component affect sound quality?
Reason i ask is the onboard sound began playing up some months ago and umpteen attempts with installing and uninstalling realtek drivers had limited success. The sound issue remained albeit intermittent.
I bought the AE-5 and all was good then the issues returned. Occasional stutters no matter the media. Youtube, spotify, netflix. Nothing major but enough to annoy.
Then bought the katana sound bar. All good but not for long. Disabled onboard audio and good time again but low and behold it is still there then goes away and you think great but it returns seemingly with no reason.
Occasionally after a windows update the onboard audio is switched on and the stutter is resolved by turning it off but back it comes sometimes within days or even weeks without issues.
It does it with AE-5 installed and uninstalled. Headphones through AE-5 or katana it will appear when it decides so i can't even eliminate a single component for blame.
I have had enough and i'm at the stage where i want to replace the whole system but sleeping on it it seems a bit extreme.
Occasionally if i reboot enough times it will behave but waiting for it to return spoils any enjoyment of films or music.
Have updated the katana and AE-5 drivers to no avail.
I know when it is not working as when i circle the mouse and follow the pointer onscreen there is a blip with the pointer trail. Like a split second outage.
This is driving me mad. Do i need a new MB, CPU and PSU or is there a simple solution?
TIA
Could be wrong on this and its not easy to diagnose such faults but sounds like it could be a failing hard drive or failing RAM modules. That could explain the stutter issue. Power supplies can cause weird issues also especially if not providing a clean and stable energy to the Pc parts. If you can borrow the parts from another pc system or have more then 1 ssd and ram you can diagnose easily.
You would really need to replace 1 component item at a time and retry the system, but I would go with main windows hard drive first, ram, p/s these are the usual suspects but some freaky stuff can occur like a bad gpu even.
I would also disconnect the system as much as you can, ie disconnect all hdds even a dodgy one connected to the system can cause issues, just one hdd at a time say the main windows hard drive only. And if you got 2 ram stick modules, try 1 only and at a time etc
Diagnostic tools you can try but just since your hdd or ram has passed does not mean there is no fault. I tested a SSD which passed all test after 4hrs but could see Windows was pausing time to time randomly, swopped the SSD and now works perfect. Same with ram modules in the past.
Baring a full on diagnostic sometimes your cpu and mobo is just bad even.
Thank you for a very comprehensive reply. Since my last post stating all was good we are back to micro stutter again. Appreciate all the possible fault finding advice but i have decided to just start afresh. Full system inbound.
Working full time with a family i would struggle to try all the various tests, reboots install/uninstall etc but appreciate your advice.
System is five years old so likely needs a refresh. Fingers crossed on the next one![]()
