What sort of software would you do that with?TrUz said:Best thing to do is: Re-install your OS, install all your drivers, programs you always install etc... Defrag, tidy up then take an image. Anythings goes bad, load the image!
TrUz
With Acronis you can store the image across X amount of DVDs or on the Acronis secure zone. But I would only recommend using the secure zone or you create it on a seperate hard drive to your system drive.sam.wheale said:What sort of software would you do that with?
Wouldn't it take up a huge amount of space - how would you get on with storing it for a future emergency...
I think when I did a rebuild earlier in the year my C:\ drive was about 15 GB![]()
That was just drivers and essentials.
I suppose you'd back it up on 4 DVD's or a separate HD or partition![]()
SW.
Thanks for the infoTrUz said:Couple of people have asked so here is what I do.
Software used:
- Windows XP
- Acronis True Image
Re-built and Image:
- Download XP SP2 if not already integrated.
- Download all drivers for your hardware.
- Disconnect your PC from the internet.
- Format and re-install Windows
- Install service packs and updates (if any).
- Install drivers for your hardware.
- Install any programs you wish to be on the image.
- Install Acronis True Image.
- Clean any un-wanted rubbish from your PC.
- Defragment your hard drive.
- Reboot.
- Open Acronis True Image and create the image.
- Either store the image on Acronis secure zone or burn to DVD.
Job done, you now have an image of your Windows installation that you can re-load in about 10 minutes depending on the size of the image.
Hope this helps.
TrUz
