Lovely build mate, love the look of the Loki, torn between it and the newer SF850L/SF1000L.
What screen are you using for stats there?
Mind me asking where you grabbed the piping/fittings from? TIA.
The Loki is a good unit, the transparent fan looks abit naff and you might hit coil whine lottery but it seems to be the same for most of these Seasonic OEM units.
Its a waveshare 5" screen
Piping is from Bitspower which i acquired from Caseking through OCUK.
Fittings are from ocuk, they're Corsair hydro X Series XF.
Yeah, have heard that about the Loki's, but they do look nice, so does the SFL's, still undecided if I want to give up my SF750.
Will look them up soon, wanting to do a watercooled build for ages, so eyeing up things that take my fancy!
That is pretty awesome looking, almost tempting me to build a new rig for my VR pc.
I’ve decided I’ll be buying out. Where did you get the new fan mount from as I would defo want to mount a few fans on the back
2 fan would work fine, my rads are strapped the back of desk. Fans just to put air over vrm and stuff like that
That's good to know about the D5 Next, I'm considering using one of the for my next build instead of reusing the Aqua Computer USB D5 I have already. Not sure if I'll go with the leak detection system that you can get on their reservoirs.
Loving the case, it's great to see something different.
Leakshield is a wonderous piece of kit, powered by magic and elves, but it can also be a royal pain in the arse as well- constant alarms for leaks that dont exist, issues with filling sensor and levels etc. Is one of the reasons I ripped out my hardline loop and went back to air cooling as I couldnt be arsed with it any longerThat's good to know about the D5 Next, I'm considering using one of the for my next build instead of reusing the Aqua Computer USB D5 I have already. Not sure if I'll go with the leak detection system that you can get on their reservoirs.
That's a very weird but well done build you have there good sir![]()
Hi, just looking at your build above with the panel mount. Any idea on a solution for an EK7" screen onto the Xproto-L grille at he bottom half of the GPU side? Looking to put a screen into my build but can't find anything, Cheers.
Place for fan mount https://imgur.com/a/0sDonEb
