- 11 Jun 2021
- UK
That looks actually amazing. Curious how dusty this type of build would get
Yeah ditto on dust as Jay85 said, I mounted two 280mm rads each side of my Xproto-L on the AIO mounts and then push pull fresh airflow inwards to the middle of the PC. I put 80 mesh dust filters on each outermost fan and that catches micro dust, the rest of it I just blow it out with a PC blower handheld I bought on Amazon. I have got a hepa air filter in my office that seems to draw most dust into that instead of my PC. Little cleaning required with openair.
I had to buy the c extender because I installed the aquacomputer quadro in the middle and all the cabling for the pump, etc. Only way I cut down on bulk was using Cablemod silver sff unsleeved cables.Much prefer this now over enclosed cases, i feel like design wise its easier to build in as well. I do regret not getting the middle 30mm extender, would have made cabling a little easier but no biggy.
Yeah the PSU molex bending inwards just made me leave whole area alone. I actually used the SSD holder that came with the standard L kit and drilled two holes in it for the quadro and then fixed that into behind the MB window where the PCIE ribbon cable passes through. However with that c extender I literally had 2-3mm play in the PCIE cable, a few heart stopping moment in this build where things didn't line up and I'd be scratching my head for days on how to do it cleanerI did it the other way and hid it next to the PSU and a bulk of the cabling for all the aquacomputer stuff tucked underneath the case feet. My initial plan was to mount the hub underneath the feet on the inside but as you’ve probably figured out as well, there isn’t enough room especially with the Molex power plugged in.
The other thing i wanted was the infinity bar in the middle but it was out of stock at the time.
Very nice and if you can afford it why not. I don't think you'll be needing to replace it for a long time.
i bet you said that about the 3090... you have a problem hahahAbsolutely will not be needing to for a very long time, i think im set for the next 5 years at least. It's an absolute monster...
What’s a shibs
its a nice looking little case, can we see it? whats the system used forOh its my Discord name, the guy who printed me the case added a personal touch lol.
that's definitely comingSee you didn't just cave in, you dragged me down with you lol still think you should Waterblock that thing.
