Thermal paste with CPU or cooler?
5 Dec 2008
Oxfordshire
Hey guys,
Going to be ordering my Intel Q9550 and Arctic Cooling freezer 7 pro soon :D
Just want to know... Will one of the 2 come with thermal paste or will i need to buy some separate? If so what would you recommend?.
The heatsink will have compound pre-applied to the contact surface. While most recommend to remove this and apply something like Arctic Silver compound, I've found the pre-applied stuff more than sufficient. Unless you're planning on some major overclocking, just go with that.
Pay more attention on the heatsink and the fan rather than the thermal paste.
Most pre-applied thermal paste can do the job even for some overclocking.
For major overclocking, thermal paste may not take too much role in overheating.
Hope this helps!
Bill
