thermaltake big typhoon
Permabanned
10 Jun 2005
ok i am going to buy the thermaltake big typhoon but i want to know what the best 120mm fans are to replace or go on top of the stock fan? i want a quiet but very powerful 120mm fan any suggestions?
Papst are the best fans though OcUK don't sell those, Vantec Stealths are supposed to be pretty good and quiet.
omg i just found the 'Thermaltake A1926 Thunderblade 120mm Blue LED Fan' are those specs rite? - Fan Speed 2000rpm, Noise Level 21dBA, Max. Air Flow 78 CFM
ok cool i think i will actually put the 'Thermaltake A2329 Silent Cat Fan 120mm' with a slightly higher 62.2 CFM and the noise level the same as the stock with only 16dB(A)
nick_lerwill said:
what it good tho?
I'd personally reccomend getting the XP-120 like has been said before. The Big Typhoon is a good cooler, but so is the XP-120 and there's less hassle changing fans with the XP.
ah but the silent cat is a different fan, i was maerly saying the thunderblades were loud but hey if u want a load fan then get a thunderblade the specs on the thermaltake website are wrong their is no way that fan can push 78cfm and only be 16db
