- 24 Feb 2017
- uk
![](https://farm2.staticflickr.com/1963/30011127177_8cd82a5938_z.jpg)
Right guys, I had to start the Mod again, with me changing the back distro, it meant all my sizes were out.
I started with a simpler design but still has the WOW factor, I think this is just down the the size of the case, I did remove the second loop. I also have to change how I want to mount the panel back to the case, I did want to keep both side panel but I will be removing one of them.
![](https://farm5.staticflickr.com/4830/32214615898_4d74128c9a_z.jpg)
![](https://farm5.staticflickr.com/4804/32214615698_14dd6e4295_z.jpg)
Once I made the new back, and sorted the mount for the top panel and side panel, I was happy to start the internals.
I started in the basement I recut the bottom panel this is 20 mm from the base of the case I have done this to hide the cables going to the 3 control boxes, which will sit behind the screen you should be able to see these from the right hand side and the top of the case.
![](https://farm5.staticflickr.com/4875/46085869181_567e47cd41_z.jpg)
Once I was happy with this I started with the side panel which will hold the screen, I am using the screen to show celebrate thermaltake product over the last 20 years.
![](https://farm5.staticflickr.com/4867/46035845702_1127f50674_z.jpg)
You can see I am sticking to the plan I submitted to the competition.
These are the cable combs I will be using.
![](https://farm5.staticflickr.com/4913/45174192795_d71c6d8b66_z.jpg)
I even made some little brackets to hold the mid plate in place,
![](https://farm5.staticflickr.com/4904/44269716570_33deff4860_z.jpg)
Once I installed the brackets, I added the mid plate which will hold the motherboard, passthroughs and another custom distro plate. I will be keeping the mid plate clear so you can see straight into the basement.
![](https://farm5.staticflickr.com/4908/45174193945_b7afee4d30_z.jpg)
I have added the sponsors logos to the side panel, I got this mod from the modding pages on bit-tech, I have used etching cream to etch the side panel. I tested this on the project no name side panel.
I cut a TT logo out on vinyl, applied the logo and then applied the cream I left it on for around 15 min and then washed it off,
Before,
![](https://farm5.staticflickr.com/4845/32301368498_efa6ee58be_z.jpg)
After,
![](https://farm5.staticflickr.com/4896/31233773647_84c4be76a3_z.jpg)
I am very happy how this turned out, I just want it to be seen.
Now it was time to do the side panel,
![](https://farm5.staticflickr.com/4834/31233772617_53b3681fc7_z.jpg)
![](https://farm5.staticflickr.com/4866/46122147592_d3f57c08b8_z.jpg)
You will have to trust me, the panel looks great, you will see this in final photos.
Next I need to add the vinyl to the side panel and paint the screen cover, this didn’t take to long, I cut the logos on my vinyl cutter and applied them to the side panel. I have added these to the top panel which will be painted matt black and I will be painting the reverse side orange.
The screen fits in great.
![](https://farm5.staticflickr.com/4917/31233962567_f2ef86e9d3_z.jpg)
Apply all sponsors logos
![](https://farm5.staticflickr.com/4876/45449299254_72cde80ab2_z.jpg)
Test fit
![](https://farm5.staticflickr.com/4913/31233963067_3b5cda288f_z.jpg)
The panel is all set for paint,
I have also ran my cables from the psu these are now in place and will not be removed, they look great.
![](https://farm5.staticflickr.com/4842/45449195764_724266442a_z.jpg)
![](https://farm5.staticflickr.com/4831/31233786977_ab0c0ba547_z.jpg)
[URL='https://flic.kr/p/MHYSxc']Right guy's I was running out of time, and didn't want to miss the dead line so here is #TT20 hope you like it.
![](https://farm5.staticflickr.com/4848/45487936904_b35e6309d0_z.jpg)
![](https://farm5.staticflickr.com/4850/45487937974_e6303783ae_z.jpg)
![](https://farm5.staticflickr.com/4881/32339763228_3470bc0969_z.jpg)
![](https://farm5.staticflickr.com/4884/32339762788_03b2c45bd2_z.jpg)
![](https://farm5.staticflickr.com/4896/32339762348_e9c4e9959e_z.jpg)
![](https://farm5.staticflickr.com/4909/45487937504_afe90d3cd4_z.jpg)
![](https://farm5.staticflickr.com/4841/46161283562_65690eb594_z.jpg)
Hope you all like the photos.[/URL]
Sorry again that I jumped to the finished photos. I need to make sure I completed it on time
