Couple of build vids. loving this case!
https://www.youtube.com/watch?v=ra_LB2Es8f4 part 1
https://www.youtube.com/watch?v=jBAI6oEtJMg part 2
https://www.youtube.com/watch?v=r7GYYpuZklo
The View 91 looks huge but if it's not too tall and not that much more expensive then maybe....
People on the OcUK forum praising Thermaltake? This is unheard of. I remember a long time they used to get nothing but insults.
Will be up for pre-order next week and in stock the week after.
any pricing info?
It"ll be £170 (blue led) and £200 (rgb) give or take.
And oh yeh, don"t expect the latest, updated rgb fans.
this guy here painted it white...looks even sexier...if your into white chicks that is...LOL
https://www.youtube.com/watch?v=HHMwgXaRvFk
If I installed a 420 in the front and a 420 in the top do you think there would be enough clearance to route the tubing from the front rad to the res? Or am I best going with a 360 in the front?
My plan is to go res/pump-GPU-Top 420-CPU-Front 420-res/pump.
Or if you guys can suggest a better order I'm open to suggestions.
Yeah I know If I installed a 420 in the front I could only have 2 140mm fans on the front of the case and 3 fans on the inside of the case but I don't think it would matter too much?
Also I'm thinking of going for a dual D5 pump as at the moment I'm using an Ek Dbay Mx and the flow performance and head pressure is a bit lacking. I don't know if it's the way I have it layed out or I just have inadequate rad/cooling.
I currently have a 60mm 240 rad up top and a 45mm 140 rad on the rear going res/pump-240-cpu-140-GPU-res/pump.
So would a single D5 Cylinder res/pump combo be enough for my planed loop or would going dual pump be worth it seeing as I'm planning many 90 degree bends in my loop?
The only reason I'm having doubts is due to the fact that every game I play performs well in the temp department except AC Syndicate, this game at very high settings make the temps sky rocket for some reason and on my last build attempt one of the rads got so hot that one of the soft tubes slid of the bard causing a leak and fried a hdd.
I was sold until I realised there was no PSU shroud
Probably will have it in the next few weeks I expect.
