For once, the QX120 fans in white are on offer..still expensive but at least the same fans on the aio...when i got my corsair 360mm aio I had ql120 fans, and ended up buying another 3 to replace the ones on the aio so they all matched..
The info from case page is you can fit a 360mm aio in top or side, and so would match with same fans..so depending where you put, 3 other fans at top or side. You can put 3 more under the base and the light will shine through..don't know if that's something you want to do as fairly hidden...one thing I like is having positive pressure, so on my 5000x and evo cases I have 6 intake and 3 exhaust fans(3 exhaust is then through the aio on the top)..this means air pushes out through back and all other gaps rather than negative where air drawn in with negative pressure..hopefully that keeps dust down a bit as pushed out of the case. you could get some cheap non rgb fans for under the base if you don't want to get another set of fans..nice thing also is it draws air up directly onto the gpu which will be sitting above.
cables below are for the revolt psu if you're going that route, or just stick with the non atx3.0 psu, but seeing as gpu is £1700, paying a bit more for atx3.0 may be worthwhile if it protects the gpu more (need to look if anyone really having any issues with non atx3.0 psu's). otherwise there's cablemod where you can get custom cables made any colour your want, or pattern etc. i'm assuming I'm allowed to say that as OCuk don't have a custom cable part to site, so not really competing..I'll take down if people think breaking rules
My basket at OcUK:
My basket at OcUK:
- 1 x Phanteks Revolt Cable Kit, PCIe Gen5 Starter Set, White (SKU: POW-PHK-00589) = £69.98
- 1 x Corsair iCUE LINK QX120 RGB 120mm White Fan Starter Kit - 120mm (CO-9051006-WW) (SKU: FG-08U-CS) = £97.00
Total: £170.98 (includes delivery: £3.99)
. At least white case will help hide it..
