Thoughts on build.
Black ram in a white build? Are you still getting ocuk to build it for you?
Regarding mobo...no real difference. Both boards have gen 4 gpu and nvme slots only..need to check no. Of nvme slots but both more than up to task
If you want gen5 gpu and gen 5 nvme(prob more relevant) with the white boards you have to jump to x670e
I know the ram is killing me, but it's just confusing which ram will work with my system and yeah OCUK is building it.
I would rather get the 5600 dominators OCUK has but not sure it's supported with mobo and cpu.
Expo ram have extra profiles for AMD motherboards but they also have xmp profiles which works fine.
Expo and xmp are basically the same thing.
You may just have to go into the bios and set xmp profiles yourself rather than the motherboard automatically doing it on first start up.
Remember if the memory you get is not on the QVL list for your motherboard it's not guaranteed to work on that board but most memory will.
Yeah that's what is confusing am i fine to order the dominators?
I just checked manufacturers for asus board and its apparently supported.
If the team group is supported then get it.
Nah sadly the 6000hz and 6400hz aren't supported by my board, think i'll go with the dominators then can control with icue.
Is this s your motherboard QVL list ?
If yes I'm sure these are on there.
ram is easy to swap out..if OCuk aren't going to get and try the titanium ram, why not get them to build it without the ram...they'll build it with test kits and take it out before shipping...then get the titanium elsewhere and slot it in..just remember 1st boot up will be slow as it does it's memory learning....
sure if get from other vendor and it doesn't work, send it back. the lastest bios updates allow the board to be used with a 7200 speed ram...problem is new ram comes out all the time, and they're not going to be continually updating every stick on their website all the time. the way i see it if the dominator series is their best ram, it should work if their lesser ram works. I may be lazy, but I didn't go checking down the list when I bought my 6000c30 kit
