Plasterboard is heavy, dusty, and harder to cut than XPS board so at £9 a pop, might as well use XPS.
Not for painting on, also plasterboard is far cheaper and you dont need to cut it as such, score and snap.
)Haha yes I was to impatient to try and get the loo installed so my family can stop complaining about the terrible hardship of having to walk upstairs.Tidy! Good to see you've got distracted on the deconstruction with the construction bit (exactly how I work too)
Cheers.iirc you open up the back and turn the button so the logo is horizontal, there is a spring in there as well so be careful.
Cheers.
Another question if you don't mind. The floor is level but it has that black coating on the concrete; reckon I can tile straight onto whatever that is? Or should I SBR it first?
Thanks.if the black stuff is stable i would prime it with this stuff
https://www.tilemasteradhesives.co....-and-grip-multi-purpose-bond-enhancing-primer
works much better than the standard primers on "problem" surfaces.
Also started removing the wallpaper and got bored with that very quickly.
I think we work in very similar ways.Did you work it around the room/spike roller it? Despite its name it's not very good at actually self levelling!
Pushed it around lightly with a plastering trowel.Did you work it around the room/spike roller it? Despite its name it's not very good at actually self levelling!
