Looking closer at your photo, I now see it's plaster lath, I wouldn't even tile on that, & wouldn't even consider overboarding, but completely replace it.
Hmm, that's not good, not impossible but def not good
Gyproc is still plaster.
Still wouldn't trust it myself.
Wouldn't bother with the Makita, better off with a proper tile cutter, I have this one.
It has cut hundreds of tiles including thick floor tiles, been superb, will cut angles.
Table tilts & locks up to 45 degrees for bevel cutting, & max. depth of cut - 33mm at 90°, 24mm at 45°.
http://www.amazon.co.uk/Clarke-ETC1...63PG/ref=pd_sim_sbs_diy_2/279-5212735-2101432
If you having tiling machine,then the Makita will be a worth while addition to your tool kit.
As to your dilemma with plaster lathes, only you can decide whether it's better to replace.
A bit more work than you wanted, but in the long run, but replacing it will give peace of mind knowing it removes the possibility of it all come crashing down.
Now that makes much more sense that idea, a 115mm grinder with that Bosch attachment.
I would like that attachment, but I might end up buying another grinder, as mine is 125mm grinder, would have to go & have a look at one & see if it will fit.
EDIT: Just had a look at the manual & it won't fit.
Means new grinder, but with the kit are three core cutters, now that is clever.
Manual here: http://www.tilecouture.co.uk/produc...tile-cutter/?gclid=CMvp7qfEnbgCFZShtAodgngApg
Cheapest price here: http://www.lawson-his.co.uk/bosch-g...t-extensions&gclid=CIOBi-HFnbgCFcXKtAodHCkAhQ
Thanks.
Larger than what thought, but I do like them.
