Time for fuel cell / hydrogen car?
7 Aug 2017
Oxford
Next car in 2 years' time will not be a diesel for sure.
Don't believe battery powered cars is the future unless there is a breakthrough in battery technology (I am sure there will be ways to charge them quicker but not sure if it will be possible to manufacture them in scale using abundant materials).
Is hydrogen the future then?
I feel that there will be a good breakthrough with battery tech at some point although I will stick with fossil fuels for a little bit longer.
Electrics cars are already on a journey of slow improvement.
Its fuel cell needs the breakthrough and they have batteries anyway.:confused:
</repeat of monthly EV/BEV/Electrification discussion>
I doubt Hydrogen will ever be the future for passenger cars, not for a long time (15+ years anyway), virtually no manufactures are investing in any meaningful way in this so certainty not in 2 years time as there's nothing even in the pipeline from what i can see car wise let alone the huge refuelling infrastructure that would need to be put in.
Hydrogen is a lot less efficient energy wise than electric, unless you can find a magic way to produce it for free. You need to use electric to make hydrogen, then transport it to wherever, store it and dispense it, then convert it back to electric in the car. It's far simpler and a huge amount more efficient to just put the electric straight into the car.
Well a Toyota Mirai weights in at 1,850Kg and has a 5.0Kg tank and has a range of 312 miles, and takes about 5 mins to fill it, the cost per Kg is ~£15, so a full tank would be £75 or about 25p per mile, seems like a bargain vs the 1.2p per mile I pay...
Are you sure they need batteries?
Obviously, they have to convert the hydrogen into electrical energy which uses a battery in the middle.
The other negative thing is the huge amount of electricity that it takes to make liquid hydrogen, it's something along the lines of 40-60kWh of electricity to make 1Kg, so I could fill my car with electricity twice and travel over 400 miles for the equivalent of 20-30 miles of range worth of Hydrogen, and that isn't including transportation and storage of it. I can also have my own re-fuelling at home, powered by energy generated directly on my house if I want to.
Hydrogen will be great, for trucks, busses, trains, etc. but its 10+ years off being suitable for cars, until we have a huge abundance of free/clean renewable energy to create it in a clean manner then it's not really a great solution.
Hydrogen still has a long way to go in terms of R&D. If more players get involved (or one big one who goes all in like Musk) then the costs will fall off a cliff and it'll kickstart all manner of industries around it from which it will benefit immensely. At his point in time it's still at the bottom of the curve in terms of economies of scale so it's still rather expensive compared to its true potential as an energy source.
I prefer this type of refuelling compared to chargers
Which one did you use? Sounds ideal if you like refuelling 50 times a year. Most EV will fill up overnight at home.... infact so could your hydrogen car when you use it as a plugin hybrid and fill that battery up for short journeys - why buy expensive hydrogen.
Yes because the fuel cell ramps up slower and you also need to take advantage of an EV powertrain which is regen braking !!
Hydrogen needs to face up to same sort of nonsense arguments that electric does, with little basis in reality, so on that front i'll offer up - what happens when my car explodes like the Hindenburg?
Stupid dangerous stuff that should be nowhere near transport vehicles.
I am sure storing hydrogen has come a long way since then.
Only thing i can see there is a static warehoouse size of capacitors to manage national grid inrush loads for fast charging a car - it then recharges from the grid between sessions to refill. 180Wh/Kg is about 5 years ago.
Nah hydrogen is still the same, embrittlement of adjacent metals. Next.
So enough energy or not?
More reading
https://interestingengineering.com/...replace-batteries-in-future-electric-vehicles
Ultracapacitors have a much higher power density than batteries. This makes them ideal for high-drain applications like powering an electric vehicle.
