What would be the point of that, you are suppose to enter the building and go upstairs.
I've been playing it, but got stuck were you are on that gun thing trying to blow up that massive tank, dunno if you are supposed to blow the tank up or use time freeze/slow down or reverse to quickly get through the gate and down into the subway.
I couldn't find where to go on that part, so I spent ages on that stationary gun fireing at it, and when I got low on health I i got off and ran away, then once I had replenished heath and timeshift, I hopped back on and shot it some more. It took ages, but I saw no other option, and only after I killed it I found the open subway.
thia may sound dumb but im still on first level bit in the large storm drain guys shooting at you from the bridge. none of the time stuff works when i press the buttons etc. do you not get this till a later time?
feel like a noob keep dieing![]()
That's what I found as well it's very confusing in some parts. I died a few times trying to defeat the tank before giving up and just made a run for it. It's very misleading as well that they put a tank there which you can't control.
The demo ran fine for me with a GTS and older drivers. I then had the same problem as you with the full game and a new GT using Beta 169.04's. I have reverted to the latest 169.02 official drivers and the game loads up no problem. I can only presume you are using the 169.04's.Have downloaded and installed the demo, but it simply won't start up. I get a small windows which opens but closes again very quickly and then nothing.
Have tried running in compatibility mode, and as administrator. No luck. Have tried the 169.04 and 169.02 drivers. will try an earlier version tonight, but just trying to find out if anyeone else had this problem, and if so, how they got it running.
I am liking the look of this game, but it does not look too good if I can not even get the demo running.... My money may have to go to Gears of War.
