TJ07 Build with a differance - True triple chamber inverted ATX
Really great job you have done with this mate.
The only thing that I am not to fond of is the piece of tubing running from the pump to the rad, I think it would have looked better if this was left in the lower section of the case instead of going up through the midplate and back down again.
The roof window showing the graphics card looks fantastic though.
I can't wait til I get my TJ07 now.
Thanks guys, yes thats XSPC 7/16"ID 5/8"OD tubing over 1/2" barbs. No clamps needed.
Yes I did think about that tubing, it would have been hard to route in under the false floor/midplate without it kincking or some very tight bends due to the location of the outflow pipe on the pump. I wanted the rad where is is as I like the symmetry of the white tubes leading to , and out of it. Also the false floor looked very bare and devoid of any features so the extra tubing sprouting from it adds a bit of interest. I am thinking of replacing that tube with a clear one or different colour to add further interest. With the side panel on and when you cant see where the all tubes lead to, its adds a little mystery to the routing I think :)
Wow mate, that triple screen setup looks badass!!
It must be amazing to play racing games with a rig like that?
Out of interest, how much did it set you back for that setup?
Wow, Typhoon mate i'm impressed!!
That is a very nice setup, glad to see mobo + blocks went to a loving home :D
great job bud, makes my 1st little mod look a bit naff. Just a bit though. Good luck with the ac ryan hex mesh. I couldn't find any anywhere, closest was a 240 rad grill but wasn't quite big enough for me. OC now have a phobya grill similiar but the hex size is mahoosive. I even had a friend in the eng trade look for stuff - I'd searched for mesh but it's actually called erf sheet. It's available but in 2000mm x 1000mm panels.
I ended up using 12" speaker grill from 'butlins', the design of which meant 10" of the diameter was almost flat. Did the job over my blowhole but no where big enough for your side panel. Butlins did have some dirt chep atx cases with mesh sides with a small frame. Might be worth looking at this option - buy a case with suitable mesh, steal a panel and mod the case with acrylic sheet/window and sell it on.
