**TODAY ONLY! 10/04/2014** MSI Radeon 290X & AOC 27" Widescreen monitor - yes, I got it right today
OcUK Staff
4 Feb 2013
Considering I derped so hard yesterday with the title, I figured it best to let you all know that it's ACTUALLY CORRECT today :D
MSI Radeon R9 290X Gaming Edition 4096MB GDDR5 PCI-Express Graphics Card @ £379.99 inc VAT
AMD Radeon R9 290X is a new graphics card powered by the latest AMD Radeon™ R9 290X graphics-processing unit (GPU). 4GB of super-fast GDDR5 memory for the best gaming experience at the highest resolutions including 4k and incorporates AMD Eyefinity and TrueAudio technologies to enable expansive multi-display setups and more accurate environmental sounds. R9 290X also includes support for both DirectX® 11.2 and AMD's new Mantle application programming interface (API) for great handling of even the most-demanding PC games.
Specification
- Backplate included: Yes
- GPU: Hawaii XT
- Litecoin Hash Rate: 850-1000
- Stream Processors: 2816
- ROPS: 64
- Core Speed: 1040MHz
- Memory Speed: 5000Mhz
- Memory interface: 512-Bit
- Memory capacity: 4096MB GDDR5
- Cooling: MSI Twin FrozR Gaming Cooling
- PCI-Express X16 lane required
- 600W or greater PSU required
- Power Connectors: 8-pin + 6-pin required
- Display Outputs: 2x Dual Link DVI, 1x HDMI, 1x DisplayPort
- Warranty: 3yr
Features
- DirectX 11.2 Support
- Open GL 4.2 Support
- Dolby TrueHD and DTS-HD Master Audio support
- Crossfire Support upto 4-way: Native software crossfire (No bridge required)
- Gaming @ 4k Resolutions (UltraHD)
- Synergy with next-gen game consoles (Mantle)
- Graphics Core Next (GCN) architecture - optimized from previous generation products
Only £379.99 inc VAT.
ORDER NOW
_____
AOC Q2770PQU 27" Widescreen LED Monitor - Black @ £319.99 inc VAT
Experience a new level of sharpness with this large 68.6 cm (27”) monitor. The q2770Pqu utilises a state-of-the-art Super PLS panel with the stunning WQHD resolution of 2560 x 1440 pixels. With its D-Sub, DVI-D, HDMI and DisplayPort connectors, plus speakers as well as a USB hub integrated into the bezel, this energy-efficient display offers you a multitude of applications, delivering exceptionally crisp and vivid images for even the highest demands. Benefit further from full ergonomic flexibility with 130 mm height adjustment, tilt, swivel and pivot (= portrait mode rotation) function. The q2770Pqu comes in a classy black texturised design and features eco-friendly LED-backlights .It fulfils sustainability certificates such as Energy Star 6.0, TCO 6.0 and EPEAT Gold. Let the q2770Pqu impress you today!
Specification:-
- Monitor Size: 27"
- Visible Screen Size: 68,6 cm
- Screen Format: 16:9
- Brightness: 300 cd/m² (typ)
- Contrast Ratio Dynamic: 80.000.000:1 (DCR)
- Contrast Ratio Typical: 1.000:1
- Pixel / Dot / Pitch: 0.311 (H) x 0.311 (V) mm
- Display Area: 597.89 (H) x 336.31 (V) mm
- Viewing Angle: 178°/178° (CR=10)
- Response Time: 5 ms GtG
- Maximum Resolution: 2560x1440@60Hz
- Recommend Resolution: 2560x1440@60Hz
- Colors: 16.7 M
- Connectivity: 1x VGA, 1x DVI-D, 1x Display Port Input, 1x HDMI
- Dimensions (WxHxD): 642 x 558 (+130) x 245
- Weight: 7.5 kg
- Warranty: 3 Years
Only £319.99 inc VAT.
ORDER NOW
Great price on the monitor. Shame im opting for a 4K one :( But im sure there will be people that don't want to have to buy the necessary GPU power for 4k and this offers a cheap 1440p option.
Thanks Gibbo :)
(OCUK might want to add a few more stars to that monitors review, he likes it but only marked it down because it didn't come with a meerkat!) :D
Quite tempting to upgrade to that 290x from my current 7850.
Quick question though, is the price gap between the 290x and the 290 worth it? Because from a quick check at benchmarks there is literally up to 5fps difference between them but I was wondering if that's changed now with new drivers etc?
Being picky, but your promo blurb is slightly incorrect on the monitor being the cheapest on the market. The DGM is cheaper on some sites. Have to admit that I'd rather buy the AOC though :)
Thanks Gibbo :)
We can't we can only authorise or delete a review, not modify it.
That one should not have really being authorised as it does not seem real. Still great monitor!
