what exactly is the point of the cloud controller? or the cloud key? if i can access the control of the wifi network via a PC (if it's on) or my mobile, then what would i need the cloud for?
I believe that rate limiting is one of the features that would require the controller to be running.
It isn't something I could easily test. Try asking in the dedicated thread on here, or head over to the manufacturer's support forums.
The UniFi kit isn't really aimed at domestic users so you don't get much in the way of hand holding. They're popular because they're relatively cheap for what you get.
