OcUK Staff
- 23 Feb 2015
- Overclockers UK HQ
Hi all,
We have been working hard to make sure this product is available to you and are now pleased to say you can now place your pre-orders on for the TPCast Wireless Adapter for HTC VIVE!
The production run should complete in the middle of September and so hopefully the first units will land with us 4-6 weeks later. I have the ETA set as mid-October but expect them between then and the end of October. Our allocation on the initial run is limited as they have had to supply launch partners all around the globe so get your pre-orders on ASAP to avoid disappointment!
TPCast Wireless Adaptor for HTC VIVE @ £318.95 inc VAT https://www.overclockers.co.uk/tpcast-wireless-adaptor-for-htc-vive-vr-000-tc.html
TPCAST Wireless Adaptor for HTC VIVE, Easily Upgrade your HTC Vive to a wireless VR HMD, Highly optimized antenna array, Large Bandwidth, Virtually ZERO Latency
Experience something you never have in VR before! Experience total freedom. Freedom to walk and meander through a beatiful landscape, freedom to spin and turn and jump!
TPCAST Wireless Adaptor for VIVE is an accessory developed specifically for HTC VIVE. It enables HTC Vive owner and users to easily upgrade their HTC Vive to a wireless VR HMD. With highly optimized antenna array and large bandwith, it ensures the display quality is the same as that with a cable.
Features
• Easy to Install: The TPCAST adaptor replaces the HTC Vive cables following a straightforward and easy installation.
• High Resolution: The transmission delivers up to 2k display resolution and provides an extraordinary virtual reality experience.
• Immersive In-Game Experience: Getting rid of the HTC VIVE cables enables 360 degree of free movement.
• Long Battery Life: Battery pack provides up to 5 hours of operation.
• Extraordinary Comfort: The TPCAST wireless Receiver, attached to the HTC Vive is very light and small.
• No Visual Distortion: The adaptor preserves the high video frame rate of 90Hz (90 frames per second).
• Near Zero Latency: The adapter adds less than 2ms latency assuring a seamless VR experience.
• Two-Way Interaction: Signals are transmitted back and forth between the PC Transmitter and Receiver.
• Broad Signal Coverage: Signals can reach up to 5 meters with a 360 degree angle.
Specifications:
• Video Format: HDMI 2.0.
• Video Resolution: 2K (2160*1200).
• Frame Rate: 90Hz.
• Audio Format: 16 bit 44100Hz, 16bit 48000Hz.
• Wireless Transmission Latency: < 2ms.
• Signal Range: 5 meters, 360 degrees.
Includes:
• 1x PC Transmitter.
• 1x HMD Receiver.
• 1x Power Box. (with a 20000mAh power bank)
• 1x Router.
• 1x USB Connection Line.
• 1x HDMI Connection Line.
• 1x User guide.
HTC VIVE Not Included, sold seperately.
Only £318.95 inc VAT.
ORDER NOW
LINK TO USER GUIDE
![](https://img.overclockers.co.uk/media/image/thumbnail/VR000TC_171747_285x255.jpg)
![](https://img.overclockers.co.uk/media/image/thumbnail/VR000TC_171748_285x255.jpg)
![](https://img.overclockers.co.uk/media/image/thumbnail/VR000TC_171749_285x255.jpg)
![](https://img.overclockers.co.uk/media/image/thumbnail/VR000TC_171750_285x255.jpg)
Features
Specifications:
• Frame Rate: 90Hz.
Includes:
• 1x HMD Receiver.
• 1x Router.
• 1x User guide.
ORDER NOW
LINK TO USER GUIDE
