trojan problem
Permabanned
19 Dec 2006
keep getting this in nod32.
when i try to remove it - access denied - file is locked.
when i try to rename it - access denied
when i try to do anything with it, access denied.
looked under processes and its not running...
Can you boot in Safe Mode and try manually deleting it?
Press F8 like a madman when your Pc is booting to get the option to use safe mode.
I had something similar in BitDefender in the end I disabled BitDefender, Disabled system restore, deleted the file then purged the recycle (norton protected) bin (a legacy from NAV 2003), enabled BitDefender, did virus scan (nothing found), enabled system restore.
Might Help! Good Luck!
