Simon said:The engine revs go up so extra fuel is added by the engine management ready for the higher engine speed and hence more fuel requirements, however your clutch control suddenly stalls the engine and this extra fuel doesnt get burnt.
When you come to start the engine again this extra fuel make it difficult for the mixture to ignite. Its taking a while to start as when your cranking the engine over the air is 'cleaning' the extra fuel out and then it can start.
Try opening the throttle a little when you start it to let more air in.
Thanks Simon.
So, before turning the ignition, I would press down on the gas a little, and keep it at that position until the engine turns over? If so, how far down do I need to press the pedal until the throttle opens enough for the extra air to get in? I would guess 2/3 inches, would that be enough?
Also, do you have any ideas why some cars can restart straight away without needing to 'remove' the excess fuel?
