it's fine, i was just kidding, 1600w is plenty for that specThough genuinely, I would have assumed that two 4080s would be fine on 1600w? The total max draw according to pcpartspicker is something like 1020w.
correct, just make sure the cable is fully inserted on both ends, and also that the cable is slack (ie no tension on the cable)Just the single cable from GPU to PSU? I seem to remember melty cable issues but presume 600 to 600 is correct?
I think the Super version used the updated 12v-2x6, not sure on the original 4080, but they're pin compatible anyhow.Just the single cable from GPU to PSU? I seem to remember melty cable issues but presume 600 to 600 is correct?
On my now blown Thor I used cablemod 600/12vhpwr to a split thing with 3 x pcie.
Tbh not even bothered about the RMA (not least because I'll have to sell the bloody thing!)
might as well buy the euromillions at the same time tooKeep it as a spare. You know, just in case you suffer a PSU failure...![]()
