"turbos smokes a bit after full load"
Hmm i'm not sure what i'd do with this car, its quite cheap due to the turbo and a very short MOT, two problems i can see, getting someone to fit a new turbo is going to cost around £400 thats if your current one can be refurbed, second bigger issue is older 5's like to rot so check the sills with a fine tooth comb!
Thinking about it i'd pass on this car, buy a good solid Mk1 1.8 enjoy it then turbo it at a later date, BBR's are alright but not really that fast vs aftermarket setups.
Sills and arches have all been done and look 100%
I could ask him to MOT it tbh
a hooky MOT would take care of that though. id use the smoke as a point to knock money off anyway. if it fails, just get something BIGGER
Most Recent Vehicle Details and Test Summary applicable to this test number.
Registration mark: J555MXV
Make/Model: MAZDA / MX-5 SE
Colour: BLACK
VIN/Chassis No: xxxxxxxxxxxxxxxxxxxxxxxx
Approximate date of first use: 30/12/1992
Type of fuel: Petrol
Date of test: 24/10/2008
Certificate issued (Pass)
Odometer reading: 89,723 Miles
Test number: 211958698250
Test expiry date: 07/11/2009
Full Test History, starting with first recorded vehicle and test results
Make/Model: MAZDA / MX5
Colour: BLACK
VIN/Chassis No: JMZNA18B201126633
Date of test: 09/09/2005
Certificate issue refused (Fail)
Odometer reading: 89,136 Miles
Test number: 450312255281
Test station name: TYRED & EXHAUSTED
Test station number: 28947
Test station telephone number: 01670352971
Test class: IV
Reason(s) for refusal to issue Certificate
Offside Rear Seat belt anchorage prescribed area is excessively corroded (5.1.B.6)
Offside Rear Seat belt anchorage prescribed area is deliberately modified which significantly reduces the original strength (5.1.B.6)
Nearside Rear Seat belt anchorage prescribed area is excessively corroded (5.1.B.6)
Offside Front suspension has excessive play in a lower suspension ball joint (2.5.B.1a)
Offside Rear parking brake recording little or no effort (3.7.A.7a)
Parking brake efficiency below requirements (3.7.A.9/10)
Advisory Notice issued
Corrosion noted in genral on underside of vehicle,floors,chassis,axle front and rear,and front and rear suspension components
Date of test: 23/09/2005
Odometer reading: 89,204 Miles
Test number: 581106665257
Test class: IV
Test expiry date: 22/09/2006
No Advisory Notice issued
Date of test: 03/10/2006
Odometer reading: 89,612 Miles
Test number: 712186976289
Test station name: V C SAVAGE
Test station number: 50952
Test station telephone number: 01782319839
Test class: IV
Test expiry date: 02/10/2007
Front and rear upper and lower suspension arms heavily corroded, rear brake discs corroded, o/s/f tyre worn on iner edge.
Change of details
Make/Model: MAZDA / MX-5 SE recorded at time of test on 03/10/2006
Date of test: 08/11/2007
Odometer reading: 126,633 Miles
Test number: 730072817379
Test station name: STONE CAR AND TRUCK CENTRE
Test station number: 55346
Test station telephone number: 01785814385
Test class: IV
Nearside Rear Brake disc(s) excessively pitted (3.5.1h)
Odometer reading: 126,634 Miles
Test number: 540532617319
Test class: IV
Test expiry date: 07/11/2008
Date of test: 09/10/2008
Odometer reading: 89,722 Miles
Test number: 641933888286
Test station name: CROWN STREET GARAGE
Test station number: 0673AD
Test station telephone number: 01785818137
Test class: IV
Nearside Front Headlamp aim too high (1.6)
Offside Front Lower ball joint pin Suspension arm locating pin locking device not properly locked (2.4.G.4b)
Front brake application uneven (3.7.A.2c)
Offside Front brake binding (3.7.A.2a)
Offside Rear Anti-roll bar linkage has excessive play in a pin/bush (2.4.G.3)
Nearside Front Subframe mounting prescribed area is excessively corroded (2.4.A.2)
Offside Front Subframe mounting prescribed area is excessively corroded (2.4.A.2)
Offside Front chassis Subframe mounting prescribed area is excessively corroded (2.4.A.2)
Nearside Rear inner sill Seat belt anchorage prescribed area is excessively corroded (5.1.B.6)
Front brakes imbalanced (3.7.A.2e)
All ferrules Brake hose slightly deteriorated (3.6.B.4d)
Test class: IV
V5 says he's owned it since '05 *walks away*
So did Crown Street Garage fix all that stuff then? If so, it may not be that bad - that sort of corrosion is common on older Jap stuff. Our FTO had a similar MOT failiure - got it all fixed and it passed.
Gut feeling says 'shed' though.
Not really a shocking list of failures, about what I'd expect for an early 90's Japanese car. Tyred & Exhausted's corrosion repairs can't have been that amazing to last 3 years though.
What's the deal with the milage, that's all over the place. According to the ad, and those MOTs it hasn't done any milage for 4 years - unless it's had a swap out on the dash cluster.
Either way, that rust looks pretty scary. Nothing gets rot out... :(
my turbo started letting out the odd bit of white smoke on the way out, the point is that if it gives up it could take the engine with it.
