**TWO CRAZY ACER 3D 120Hz MONITOR DEALS!!**
I'm starting to slightly regret buying one as well now, the buzzing has been getting worse, I tried putting it back to 60hz and it still buzzes but it's very quiet. After a bit of googling it seems if you send it back to acer they just send it back saying there's nothing wrong with it.
http://forums.overclockers.co.uk/showpost.php?p=24359822&postcount=12
http://forums.overclockers.co.uk/showpost.php?p=24360322&postcount=13
Acer called me back enventually. (The idiot couldnt read down email to find my proof of purchase, good start!)
They will not replace it since I did not report the fault within 5 working days (how the $£$% was I supposed to know that, OC never informed me of this when I contacted them immediately with the problem.)
So they will only take it away and repair it.
Simply disgusting customer 'service' from Acer. It is a clear known issue with these units and this how we get treated?
Sorry OC but this one is on you. I have no option but to return this via OC RMA as Faulty.
Extremely annoyed and disappointed!
Where do you get the idea that Caps can't buzz from?
http://www.youtube.com/watch?v=WJxlNDliSUs
Pretty much exactly the buzzing coming from the monitor.
I used to work for Pioneer by the way.
Would you say it's poor quality caps or something else causing them to buzz? If a simple change of caps will fix the buzz I have no problems throwing my warranty away to change them!
