Two monitor setup
19 Apr 2012
I currently have a 24.5" Full HD 75hz display from Iiyama. Ive no issues with the display itself but having got used to using a dual monitor setup at work, I feel a bit deprived back on the home computer.
I would be looking at getting a 1440p 144hz I think to compliment a new Ryzen build but have a few questions.
Can I run one monitor at 144hz and a second one at 60hz?
Ideally I would need them to match so it didn't look out of place.
I presume I wouldn't be able to run one at 1440p and the other at full HD?
Either that or I just get rid of the Iiyama and get a decent but larger 27" monitor and suck it up.
No issues running 1x1440p 144hz and 1x1080p 60hz, it's all down to what your graphics card can handle, but most modern ones should be able to manage that fine anyway.
Excellent. Thanks for your input. My graphics card is a Vega 56 sapphire pulse if it makes any difference. I'll have a look through the settings when I get a chance. I'll maybe test with old old monitor as a secondary before I take the plunge.
I've got a new Dell S2719DGF (1440p 155Hz)and an ancient Dell U2211Ht (1080p 60Hz), although I have actually unplugged the smaller screen as I've been having AMD driver issues with my 5700XT and two screens. However it should be fine with the Vega 56 as that's got more work on the drivers.
I really like it...but I'm coming from the U2211Ht which is lower res and just not as good anyway, so it would be nicer. The only downside, imo, is that the colours and settings out of the box aren't quite as true as I'd like. For Windows and Gaming use, it's basically no issue but for photo editing it's a bit annoying as I'll edit an image to look great on this but it doesn't look so good when viewed on other displays (phone etc.). Sensibly I should get a second, more photo orientated display for editing though.
