Ultimate Girl's PC Case?
I'm not sure who's gonna cut it out....
And i'm certain i want the case pink, not just loadsa LED's
your only 15 yes? or 16, so philstanbridge doing a case for you no offense but might be way out your price range.
16 and yes i wasn't plannning on spending a hell of a lot
thats phil out the question then lol! hehe!
i found this on the other hand though...
its a bit urgh to me.
I REMOVED LINK!! COMPETITOR HEAVEN MY BAD!
irony is shes only used it half a dozen times in 3 months, tried to get her interested in computers!, she also doesn't realise the amount of work that went into it!
If i was your daughter i would truly appreciate all of your hard work and would be interested in computers
ADOPT MEEEEE :D
just used standard car paint, all ford colours iirc - the paint finish and filler finish isnt perfect - but i wasnt going for show n shine, painting the interior black helps too.
heh you cant see inthe pics but i also made her desk!
Nice! About how much is it a can?
Also the plan now is to use pink furry material (although cooling is going to be a concern) Should be a funky case when its done!
Ta
the paint isnt that expensive, about 1.80 for a small can - the bigger cans are cheaper, basically painted it all - wet flatted with 1200 paper then laquered the whole thing - shiny!
work i did inside - altho i changed the ide cables to round UV later
custom drive cages
Sweet dude! What case is that, and did you use the Vantec sleeving kit? Also, I am loving that pink hairdryer :p
no idea what the case is, there wasnt much left of it after id finished anyway, i found the case at work, was just a scrap one, cant remember where i got the sleeving kit from i just remember it being a pig to do - id do it again tho :)
pink hairdrier - not mine honest! - great for heatshrink tho!
Luna - doesn't that black scratch really easily?
Looks good though. Think thats going to go in the design aswel :)
Should be getting all the stuff in town this weekend, still not exactly sure what to do on the dirve :rolleyes: fluffy would be cool but "might"... just might go into the mechanism which wouldn't be good. Thoughts?
ta
