Find the power on option in the lcd menu
Thanks, it's a bit of a roundabout way but it works
Thanks, it's a bit of a roundabout way but it works![]()
You can reorder the menu so it's on the first "page" or map the command to a button.![]()
You can check compatible equipment at Logitech compatability checker
They are quite easy to set up and tweek to your needs, I cant recommend them enough. The one seems to be a popular choice and the activities works exactly how you describe macro's.
go for it
I am sure the squeezebox will work with it as its made by logitech![]()
Thanks, actually the squeezebox was not made by logitech, logitech brought "slimdevice" out a couple of years ago, great piece of kit though.
Got a question:
or would it somehow know the TV is already on ?
Can the 1000 do this? I like the idea of hitting one button and having everything turn on and the TV going to the right HDMI input. Sounds rosey.
