I have read that the new models can't be unlocked by flashing a new BIOS but what about this thread where they talk about modding your existing BIOS to unlock the shaders?
Anyone tried this? I am tempted to try it to get a free upgrade but scared I brick my card
1st, you'll want to save a copy of your existing bios. You can follow the bios flash guide steps 1, 3 and 4 to save your bios. This is just in case something doesn't work right (not all 6950 GPU's have fully function shaders). The flash instructions are here: instructinos
Just do steps 1, 3 and 4.
Next, download this: www.techpowerup.com/wizzard/Mod_BIOS_HD_6950.zip
Extract the script and copy over the original saved bios into the folder for this script. It needs to be named "original.bin"
Now run the script (it will tell you instructions) and follow the original flash instructions with the modified bios. ( instructions ) follow steps 5 through 9 with the modified bios created with the script ( modded.bin )
