pretty much most thermoplastics will be melted at 250C. i used to work as a injection molding technician in a plastics factory, and the melt temperatures ranged from about 180C (polypropyline) to 250 - 275C (nylon, polycarb,ABS ect)
i just looked at a plastic handle on a cooking utensil (nylon) and it says heat resistant to 230C - it will start to melt not much higher than that
Also consider what you're using it for, as the plastic might soften sufficiently to make it unusable at a temperature much lower than it's melting point.
