- 22 Feb 2020
I got my son a PC about a year and a half ago. At Xmas I upgraded the GPU to a GTX 1660 Super which made a big difference (old card was a GTX 1050 2Gb) but he is still not really getting smooth gameplay in games like FarCry5. The rest of the spec is:
AMD Athlon X4 950 CPU
8GB DDR4 2400MHz RAM
Seagate 1TB FireCuda SSHD Hybrid Drive
Fractal Design 80 PLUS 500W PSU
...I noticed the CPU was maxing-out when he was playing farcry but pausing the antivirus continuous protection function helped a lot (it had been using 20% CPU). Basically, I was thinking the CPU is probably the next thing to upgrade, right? The place I bought it from had suggested a Ryzen 3 3200G or possibly a Ryzen 5 3600.
They also suggested a M.2 SSD (I do have a slot). I also thought maybe it would be worth adding some RAM. Maybe adding 2 sticks of 8GB 3200MHz RAM instead of the single 8GB 2400 stick I have?
He doesn't have the cash to do all of this though...what do you think would be the biggest bang for his buck? Would it be better to go with the Ryzen 3 + SSD, or Ryzen 5 now and get the SSD later? Or just do the RAM first?
Thanks!
Thanks!
