- 22 Feb 2020
Cool. Is it worth spending £5 more to get the overclocked 2600x with the Spire cooler?
You've done the right thing by checking where the performance problem lies. Don't bother with the 3200G as you already have a GPU. The bang-for-the-buck CPU is the Ryzen 3600.
My basket at Overclockers UK:
- 1 x AMD Ryzen 5 3600 Six Core 4.2GHz (Socket AM4) Processor - Retail= £154.99
- 1 x MSI B450 TOMAHAWK MAX (Socket AM4) DDR4 ATX Motherboard= £98.99
Substitute the MSI Mortar Max if you need a mATX motherboard.
RAM prices seem to have jumped recently.
...I've discovered that my motherboard doesn't support overclocking. The CPU ratio isn't a tweakable parameter in the bios. I had kind of thought I might as well go for the 2600x because I could always under-clock it if I was having temperature issues or whatever. It seems to be running fine at the moment but if I did want to dial it back a bit, could I use the offset voltage? Or I guess I could disable the boost function?
). I know my cpu only supports up to 2933Mhz but weirdly a set of 3200Mhz is cheaper.
