Upgrade suggestions
I had one full slot between mine and the top card got very loud and toasty.
Thanks, its why i asked, they are big and you had two, his case choice is better than yours (no disrespect) i don't know if that will help, but its all good info, he might still be better off with smaller slimier cards like the MSI or Tri-X.
Second time you've mentioned getting a slimier card...??
Honestly no idea what putting slime on a graphics cards does :rolleyes:
I mean, if the gaps too tight he could get a slimmer card?
Yeah I think the Tri-X would be better for crossfire.
Or reference cards and some noise cancelling headphones.
Yeah starting to think it may be better just going for the 2 slot cards, probably run cooler and offer more MB choice
Yeah, i find my self going back to when i agreed with Thefogo, the PCS+ is a great card on its own, but it prefers to be a loaner, it doesn't like to share its space with others. :)
Instead of or as well as?
Just phone them up and tell them you have changed your mind and want the MSI one instead of... or with.
Well I haven't put the order in yet, was just thinking of ordering 1 of them with the parts, and then another on its own, since its limited to 1 per order
