- 12 Jun 2008
yeah that sounds good.
now i've got £257 to spend which would enable me to get a 720 instead of a 550.
or i could keep my current system and get a 965. but is that worth it?
or with the £257 it should be a enough for a 5870?
do you really *need* to upgrade though
The only one possibly worthwhile is upgrading your gpu when the new series comes out. With respect to your memory you will notice little/no difference in speed. Im sure if you spend a little time pushing up mem clocks or tightening timings you could achieve very similar speeds anyway...
