thanks mate.Good luck mate hopefully it unlocks for ya.
i already said afew reasons why i needed to upgrade to am3. ddr3 is a very small reason. needing better pcie slots layout and more sata ports, was/is the important reasons. i wasn't going for a performance boosts.youre mad
:shakes head:
youve spent money downgrading your system????
as others have said, too late now i know, youd of been better off putting the money towards a new gfx card, 5850/5870, theres some benchies coming out from AMD showing nice performance boosts
oh well nvm
i haven't installed a fresh windows...1.325v is stock for a 720 as far as I know yea.
I'm glad you got it all setup and it's working correctly anyway, however, it's probably loading things quicker because it's a fresh install, everything seems snappier and more immediate on a nice fresh Windows install...the system should actually be slower at stock speeds than your 940, and considering you had yours clocked at 3.7GHz according to your sig ...well it'll crush the 720 until some serious overclocking is applied.
seems like a memory problem. on 1333mhz it runs perfectly. but on 1600mhz with 1.7v it just gives errors. i set the timings to 7-7-7-20 but still the same, also tryed 7-11-11-30 but still errorsI'd try reseating the cpu & memory tbh, and doublecheck the BIOS settings, memory timings etc.
If that doesn't help, try a fresh install, see if it makes a difference.
why my motherboard as the setting for 1600? also why are the 1600 ram listed in the QVL?yeah it supports 1333 if you look i noticed a few problems people were having which should be on sites when your buying ram .
Can't believe you're jumping to AM3 from your current setup! It was a good setup!
when i set it to 1600mhz , the cpu clock speed don't change, only the ram speed changes..I take it you have increased the FSB to achieve this? ...have you backed off the multiplier on the cpu so that isn't overclocked ?
Try 9-9-9-24 at 1600Mhz anyway, with a CMD of 2.
im just using a Thermalright Ultra-120a with fan 2500rpm + OCZ Freeze Extreme Thermal Compoundmy 940's *idle* temperatures are higher than that...
and im using a noctua... I'm jealous
