It should be noted that the 4790k never came with a heatsink .
That's interesting, i never knew that .
I've ordered a contact cooler , see how that goes.
Do you notice any difference in temp if you raise the voltage to 1.2v
Still seems a bit hot
I had a 4790k a while back and granted i was cooling with a dark rock2 it ran at 4.7 all cores 1.27volts and idled at about 40oC +- ish depending on room temps
Result although it's still hot. Might be worth de-lidding if adventurous. Depends on risk vs reward to you. Can always look on the bright side though, at least your room will be warm this winter.
